2004 6.0 No Pedal Response - Ford Powerstroke Diesel Forum
Old 11-14-2009, 10:19 AM
Hey, the old ladys aunt is in town from savannah and has a 04 6.0, anyway two days ago she drove up from georgia just fine. truck sat for 2 days now there is no pedal response, at the moment i do not have a scan too to hook to one that new. no lights, but i'm trying to get my hands on one to read the live data. in the meantime, any help?
Old 11-14-2009, 10:21 AM
Almostdunfukinwidit
None at all? Check the harness. If thats intact you need a new pedal assembly
Old 11-14-2009, 10:24 AM
i know the pedal assembly circuit is a complex one, are there any checks i do on the circuit?
Old 11-14-2009, 10:28 AM
Almostdunfukinwidit
No not really. Its pretty much a replace only thing. Its not all that expensive either. Right around 100 bucks
Old 11-14-2009, 10:40 AM
ok, i just want to be sure, as its not my truck or my money to spend. mine went south in my 97 a few months ago and it was erratic. at work (international) when they drop out, occasionally its a fuse, i looked over the manual and fuse box, didnt find one, so i assume ford doesn't use a fuse anywhere, am i right? also, a bad pedal tends to not set a light?
Old 11-14-2009, 10:42 AM
Almostdunfukinwidit
Sometimes it does sometimes it just stores a soft code
Old 11-14-2009, 10:49 AM
gotcha, now a dumb question, how do you unplug it, there is a little red thing that slides up and down but not sure how to work it
Old 11-14-2009, 10:50 AM
oh yeah, adjustable pedals too
Old 11-14-2009, 10:51 AM
Almostdunfukinwidit
I gotta go look but its a couple 10mm bolts and a wire harness to unclip. Not sure on the adjustable pedals though
Old 11-14-2009, 11:39 AM
is there anywhere that carries it? no one can get it here
