fuel injector teardown thread sticky
The sticky for this thread is not working. Does anyone have the link or another for this procedure?
thanks |
I noticed this as well and need to replace two injectors tomorrow night when they come in. I already have the valve covers off I am just trying to get a little more insight to this project before I get into take the actual injectors out and swapping . . .
Did the buzz test and I can hear 4 muted or fainter sounding injectors with the autoenginuity software. Is it injector time or could it just need the under valve cover harnesses?
I also swapped out another IDM before ruling it injectors and I replaced the ICP sensor. Can't wait till tomorrow night to have this thing running better again! |
I did the contribution test and returned cylinder 3 could not notice any change in engine RPM while the test was being completed. During the buzz test 1=o.k 2=o.k. 3=faint 4=faint 5=faint 6=faint 7=o.k. 8=o.k.
You need one of the tech's to respond on here . . . I'm not a tech but I act like one after my day job! lol
I would definitely try swapping someone else's IDM in before you go and buy injectors. I ruled out everything before buying injectors. Sounds to me like you have 1 faulty injector and either your UVC harnesses are coming apart a little bit or you have crap in your tank that is getting through the filter and trashing your injectors . . . |
