Leaking oil in front, blowby on dipstick - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-08-2009, 11:32 AM Thread Starter
Poweystroke96's Avatar
Hey everyone and i got a problems with my truck and im having a hard time with it. I recently arrived at school in my truck to find a huge puddle of oil just start leaking out the front. Dragged it home and with the help of my brother he figured it was the oil cooler. We took it off to find a lot of scale, the gaskets and places where the tube connects to both end adapters were rotted/gone. So i bought all the new hardware to put it back together and threw it in there. Cleaned the anti-freeze system, put all new oil and anti-freeze in. Next 2 days when i got to school i have small puddles about 3 inches in diameter dripping over the days time. Also when i got it home and ran it in the driveway i would see white "vapor" or "blowby" coming out of the dipstick, i tried to press it on hoping it would fix it but then realized it probably wasn't supposed to be doing that. It seems to be dripping from about the middle of the front of the engine what appears to be right under the fan belt. Ive talked to some friends and investigated a few things. Lastly i took off the filter for where the air goes from the intake back to where it either goes to the turbo or into the motor. I dont know what the filter or the housing that is screwed to the top of the block/cover is called. It is covered in scale and rusted/rotted up. My guess is thats my problem. If anyone can tell me what the part name is or if you think im wrong in my assumption any and all help is much appreciated. If i can today or tomorrow im gonna try to get a picture of the part up here to help you guys. Ive searched the internet for a while for a schematic or picture with the name of the part but I haven't come up with anything. I really need my truck back soon so i would like to fix it today if i can but will settle for tomorrow if i have to. Thanks again in advance
-Henry
Edit: My Truck is a 96 Ford F-350 Powerstroke XL 4x4
Poweystroke96 is offline
post #2 of 5 Old 11-12-2009, 10:38 AM
TANPOWERSMOKER's Avatar
Hey Hank,
This is Brenden post this in the 94-98 motor problem area more obs guys are on there and will be able to help and take a look.
-Brenden-
Theres Nothing Like A Good Cigar
95' F-250 7.3 EXTRACAB 4x4 LONGBED ZF5 238k
M.B.R.P down pipe,4" pipe to 5" turnouts, 6637 INTAKE, FPR SHIM, FP gauge, P.H.P. CHIP, Dana 60 swap, ccv mod, Issapro A-Piller Gauges, Aero force obd2 gauge, Rear 32gal bronco tank, 35" coopers(with no lift
), steel flatbed, home made 7ft track bars,Zf5 swap and valair cluch!!!
(I love Slaming beers...Oh, i mean gears)
SOON TO COME: Rosewood stage 1.5
TANPOWERSMOKER is offline
post #3 of 5 Old 11-12-2009, 10:44 AM
Also Youtube powerstroke blowby. A test that alot of people do is take the oil fil cap off and see the amount of smoke that pass thur. When the truck is idleing rest the cap on the fill hole if it falls of due to blow by presser not motor vibration than you got a good amount of blowby,,, just a thought.
brenden
-Brenden-
post #4 of 5 Old 11-12-2009, 11:35 AM Thread Starter
Hey brenden, thanks for the for tip ill try that. Ive read that in a few places but my only problem is it isnt my only symptom of something being wrong.
post #5 of 5 Old 11-13-2009, 05:37 AM
I think i still have a compression tester that I made for my truck kickn around. give me a shot if you want to use it and I will dig it up!!!
-Brenden-
