Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 11-02-2009, 10:39 AM
Bward Bward is offline
Truck sputters and dies
I have a 2001 F-250 powerstroke that dies at random times. It doesn't matter what the conditions are it will just die. The truck sputters and dies. Sometimes the lights on the dash (WTS, SES, ABS, ect.) will flicker with key on before turning over. When it does this it won't start at all. I have replaced CPS three times. I completely unhooked my Edge juice with attitude. The codes that i have are P0603 & P0676. I had the #6 glow plug replaced last week. Most of the time i just wait a couple of minutes and then it will start and run fine. Sometimes it will run good for a week and sometimes for a few minutes before it decides to shut off again. Please help it is getting very frustrating.
Old 11-03-2009, 04:02 PM
MikeZ3481 MikeZ3481 is offline
look at the main harness on the driver side that feeds the injectors, i had a 99 mason dump do the same thing and it turned out to be a chaffed harness causeing engine to run on one bank and die.
Old 11-03-2009, 05:29 PM
Thanks
Thanks for the info. I will check that out and let you know what i find.
