Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 11-01-2009, 04:10 PM
cutman76 cutman76 is offline
Help
96 F250 7.3 powerstroke.... Acts as if it is running out of fuel. Looses power then shuts down. Machanic said oil cooler was leaking, and fixed it, then said it was the catalytic converter was clogged, and now he say's it has two bad injectors. I don't want to keep sinking money into quess work buy the machanic, could two bad injectors cause it to run this way.
Old 11-01-2009, 04:18 PM
RRonning1984 RRonning1984 is online now
Heavy Equipment 911
Change your CPS.
Old 11-02-2009, 06:39 AM
Tach moves when cranking, Isn't that a sign that is not the problem???
