Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
  #21 (permalink)
Old 11-01-2009, 10:12 AM
Shelly Shelly is offline
BioStroker
That is some of what my pickup was doing before I had to have the darn fuse box panel replaced. But while on the machine it kicked back the fault codes for every electric part of the truck. My fuse box was real corroded - Im sure you would be able to see if that was the case.
Also - right now the truck is idling and starting like it should, (the cleaning of the EDT valve worked) but my left blinker still works intermitant and there is a electric connection noise when you start the pickup under the dash still- so the next thing that will be looked at this week is the ECM. It could be two diffent things but you never know - I will let you know what gets figured out Its a good thing I dont have a life because this would get in the way
  #22 (permalink)
Old 11-02-2009, 10:08 AM
Bio...
Ok as of this morning... same freaking issues... the truck just got picked up and taken back to the shop.
The blinker - dash issue Im being told is becasue of the Multi Fuction Switch
I hope your issues are different than mine, let me know if you want status if yours still acts up
