Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 10-22-2009, 12:39 AM
66Bronco 66Bronco is offline
TRUCK IS DEAD
Like the title says. Long story short, I attempted to load the factory file off of my Edge Evo to run some basic diagnostic stuff. In doing so, the programming process was interrupted, and I continued as per Edge's instructions. Now after about two dozen unsuccessful attempts to load the file, as well as calls to both Edge and Ford, the truck WILL NOT START. Somebody please help me narrow this down, because as of yet, all roads are leading to replacing the ECU. PLEASE HELP. Truck is same as sig.
Old 10-22-2009, 01:09 AM
chvyrkr81 chvyrkr81 is offline
Wait what did I click?
Disconnect the batteries for about 30 minutes.
If that doesn't work, you may need to get the PCM reflashed by a dealer.
Old 10-22-2009, 01:26 AM
That's the trick. According to the dealer, they can't reflash a '95. Frankly, I call bull.
Old 10-22-2009, 01:29 AM
Hmm... That sucks...
I bet you can find a used PCM for that year fairly cheap though.
There's plenty of 'em been wrecked.
Old 10-22-2009, 01:30 AM
Have you tried disconnecting the batteries for 30 minutes or more?
