Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 10-21-2009, 06:46 PM
chris cowley chris cowley is offline
How long cranking after replacing injectors
I just pulled all 4 injectors on the drivers side and replaced all the o - rings. I am told that I should crank the starter on and off without burning up the starter for 20 min. I have tried this several times but can not get enough oil pressure built up to start it. My question is - Is there an eaiser way to do this and is there any additional steps that i can do to speed this up. Thanks for the help in advance.
Old 10-25-2009, 09:20 AM
Has anyone ever had to replace an injector in the powerstroke??? If so how long did it take to start. Need help here do not want to burn up my starter.
Old 10-25-2009, 08:33 PM
got it going I let my glow plugs cycle and then cool down used a little ether to keep it going for about 10 seconds and it has been running ever since.
