Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 10-21-2009, 06:19 PM
cowpuncher cowpuncher is offline
Question Tech Help needed strange starting issues
I have checked out all the ussual stuff but when the temp drops down to freezing or below unless i put a space heater in the cab it will not fire the injectors so it wont start I really need help on what in the cab it could be its not throwing any codes eighther. Its a late 99 cclb f350 spins fine just no smoke hits on ether but its not fueling. I'm a mechanic gouing in for back surgery monday and could really use some help if anybody has seen this before or has electrical ideas sorry so long but trying to get all info out there.
Old 10-21-2009, 06:23 PM
jamstoyz jamstoyz is offline
have you checked your glow plugs? i would probably start with a buzz test.
Old 10-21-2009, 06:27 PM
glow plugs are fine, plugged it in and starts easy as long as i heat the cab up no cab heat no start I fell on to that one putting dieelectric grease on all connections trying to keep warm.
Old 10-21-2009, 06:31 PM
what do you mean by putting heat in the cab?
Old 10-21-2009, 06:34 PM
I put a ceramic space heater that u use to heat a room in the house in there and after it warms up boom the truck starts
Old 10-21-2009, 06:36 PM
that sounds really weird lol. have no clue why a space heater in the cab would fix your problem. for the techs lol
Old 10-21-2009, 06:46 PM
BRS BRS is offline
How hot are you cooking this thing? Is there any way possible you're radiating enough heat out of that big 4-door cab to keep fuel lines from gelling underneath it?
Old 10-21-2009, 06:52 PM
nope not that hot around 45 maybe 50 degrees is all it heats up to in the cab and running conditioner in the fuel on top of it.
