Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 10-20-2009, 03:19 PM
autoxsteve autoxsteve is offline
doofus maximus
All,
I did a major doofus last night. I pumped about 18 gallons of gasoline into my F250SD (6.0L powerstroke). realizing what I did at the time, I stopped and put another 5 gallons of diesel in it (to top it off). I suspect i'm right at 50/50 or so.
I plan on draining the tank and refilling with diesel. then after I fill it with diesel fuel, i'll r&r the filters.
I'll probably put the mix of fuel and gas into my Mustang - it's carbureted and may smoke but it will get used versus dumped at the hazmat station....
thoughts/advice please.
diesel doofus Steve
Old 10-20-2009, 03:25 PM
GM Duraturd GM Duraturd is offline
Dont run it with a 50/50 mix of gas/diesel. That can cause harm to injectors and I also wanna say possibly blow headgaskets but Im not positive about that.
Old 10-20-2009, 06:09 PM
95dieselsmoke 95dieselsmoke is offline
keep yer eye on the prize
I wouldnt run it in the stang either...
Old 10-20-2009, 06:13 PM
jamstoyz jamstoyz is offline
how can someone make that mistake? i can see someone who never owned a diesel but....... i think i heard someone say on here that you can run a mix of gas and diesel through our trucks but probably not 50/50. thats gonna be a lot of fuel to drain. guess you could use it for a huge bon fire
Old 10-20-2009, 08:10 PM
Robsr Robsr is offline
Yeah, I inherit about 50 gallons of gasodiesel a year, dont put it in the mustang, it works pretty good in the weed eater though, lol
Old 10-21-2009, 06:09 PM
cowpuncher cowpuncher is offline
I would try to cut it to 75% straight gas &25% mix for the stang myself probably have lack of power and maybe hard starting the 50/50 is not good for truck at all though
Old 10-21-2009, 06:42 PM
tomtom tomtom is offline
Local BP station has green pump handle on gas and black pump handle on diesel. I hate going to this station because it is so easy to do. I stopped a guy from putting diesel in his new lexus a couple of months ago. Some stations are bassackwards.
