Need help priming fuel to start - Ford Powerstroke Diesel Forum
Old 03-08-2007, 03:52 PM
Exclamation Need help priming fuel to start
Hey guys,, I removed the fuel filter housing to replace the hos going into the fuel pump. After putting it all back together, I filled up the filter canister with fuel and cranked it and cranked it.... nothing. what do I do now?
Old 03-08-2007, 03:55 PM
BIG TRUCK, SMALL DRIVER
Check the fuel pressure. It may be getting fuel. Check the fuel heater fuse. It may be shorted.
Old 03-08-2007, 04:00 PM
ill go check
Old 03-08-2007, 04:05 PM
Powerstroke Techie
did you get the connector going to the IPR hooked back up?
Old 03-08-2007, 04:09 PM
dont have anything to check it with. It has a port for checkin on it. sux to be me right now. I popped the filter cap and theres plenty of fuel.
Old 03-08-2007, 04:11 PM
im pretty sure everything got put back.. Which one would that be?
Old 03-08-2007, 04:16 PM
are the injectors easy to prime on the powerstroke?
My dodge is real easy. Iknow, everytime my wife runns it too low on fuel and goes uphill, I get to do this
Old 03-08-2007, 04:18 PM
Check fuse # 22 in the power distribution box.
Old 03-08-2007, 04:28 PM
# 22 is ok, but # 18 was bad. not sure of that yet. IS there any chance air got into the lines?
Old 03-08-2007, 04:35 PM
Did you fill the fuel housing before trying to start? If you did, it should have started and maybe cut off after a few srconds, but it should have ran.
