MAJOR oil leak. - Ford Powerstroke Diesel Forum
Old 10-17-2009, 11:13 AM
MAJOR oil leak.
Started my truck up just a little while ago.Let it run for a minute and backed up and ran inside.As I was coming out I saw a huge puddle of oil underneath the truck and shut it off. After furhter inspection it looks like its coming from above the power steering pump and also from the top of the motor starter side.you let it run it flows out everywhere.Any ideas? Dealers are closed and I have no way to go right now.Cant believe its pouring this much oil.Help.
Old 10-17-2009, 11:18 AM
mighjt be an oil rail plug o ring
Old 10-17-2009, 11:19 AM
What kind of Truck, engine mods etc. That will really help the techs out.
Old 10-17-2009, 11:22 AM
sorry.Stock 03 6.0 in an f 250. its a first run 6.0 too if that makes a difference
Old 10-17-2009, 11:43 AM
Bumping this back up for you. Hopefully someone can help you out.
Old 10-17-2009, 12:12 PM
Where is the oil rail plug exactly located.Ive never worked on this one before so I dont know,never had a problem.I drove a 91 7.3 for 12 years and worked on it.thanks for any help.
Ive re started the truck and its still pouring out.I have looked all around the back side of the engine and right where the turbo tubes come together theres a shelf like there and it looks like where that may be where its coming from.Its pourin down the passenger side. Gonna remove the fromnt turbo pipe to see if I can see above the power steering and find that leak there.
Old 10-17-2009, 02:01 PM
anyone got any ideas??
Old 10-17-2009, 05:01 PM
Old 10-17-2009, 07:11 PM
Talked to a buddy of mine and he said it sounds like a icp sensor.
Old 10-18-2009, 05:12 AM
Thanks so much westcoaststrokin I am gonna check it out and hopefully thats it.
