runs rough till it warms up - Ford Powerstroke Diesel Forum
Old 03-07-2007, 12:22 PM
Ihave a 97 4wd stock except for a kn air filter with 260000 miles.
when its cold out the truck will intermittently idle rough with a loss of power and will have a check engine light that will not throw out any codes
once the truck is warm it will not run rough anymore and the check engine light goes off. if i shut the engine off it will start and idle no problem until it goes into closed loop and then the check engine light goes on and rough idle starts again
Old 03-07-2007, 12:24 PM
ADMIN AND TECH
this is a diesel engine , you confused me with the closed loop part, diesel doesnt have that , that goes with gas engine and oxygen sensors
Old 03-07-2007, 12:28 PM
i was told when you first start the truck the obd2 will put it into a kind of safe mode then put the different sensors online this is what seems to be happening because it will idle fine for about 5-10 seconds then it will light up the check engine light and run rough
Old 03-07-2007, 12:34 PM
ADMIN AND TECH
to an extent but doesnt haved alot of effect on way vehicle runs , with a 97 model 7.3 with that mileage there could be several things causing concern, injetor wiring , ipr , icp pressures , really need to start ,with basics ,is oil in good shape and full, do you have a way to pull codes , need to know what codes are in pcm, the pcm does go thru a check once engine is running ,if it does see something light will come on
Old 03-07-2007, 12:53 PM
the oil is fine including in the hpop resevoir im thinking its probrobly not a pinched wire because it will run fine for 5-10 sec if i shut it off and restart it
i tried retrieving codes from the pcm but i didnt get any
Old 03-07-2007, 12:54 PM
ADMIN AND TECH
if the light is coming on at all you should have a code , what scanner are you using
Old 03-07-2007, 12:56 PM
i have a junk scanner so i when to auto zone to see if they could get the codes but it also came up blank
Old 03-07-2007, 12:59 PM
ADMIN AND TECH
need to run more diag , with a good scanner , like injector buzz test just to make sure no injector electrical issues , without any codes to work with its gonna be hard to diagnose ,look at all wirng close , maybe look at all your injector wiring going into vale cover , 94 - 97 are bad for melting the injector wiring ,sometimes if its bad enough you can see it on the outside , pins damaged etc.
Old 07-06-2007, 08:07 PM
i have the same problem, excpet once its warm, it completly goes away.
Old 07-18-2007, 08:12 PM
put cetane boost additive in.
Reduces misfiring during warm-up https://www.amsoil.com/storefront/acb.aspx
