HELP TRUCK DIED WON'T RESTART!!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-08-2009, 02:28 PM Thread Starter
Cumminskiller2007's Avatar
Have a 2001 f350 7.3, had the LPOP replaced about 4 months ago, it has been hard to start lately, was at work went to leave started right up made it maybe 20yds spit sputtered and died if let sit for 5-10 min will start after cranking a while but runs bad and sounds like injectors nocking, found bad battery replacing it tomorrow, need some input Im kind of leaning toward HPOP but don't know how to check the pressure, would a bad battery cause this???
2001 F350 S/C 4x4 DRW 6spd
475K
DpTuner-high idle, 80E, 100Perf, 120Race, 4inch TB exhaust with 5in. Single black Stack, Custom 4in. intake with AEM dry filter, ISSPRO boost,pyro and water temp, zoodad mod, Beans 1.0 A/R non wastegate turbine housing
Cumminskiller2007 is offline
post #2 of 2 Old 10-09-2009, 07:12 PM Thread Starter
anybody
475K
