Truck missing really bad
Today when i was leaving for school i made it 200 yards down the road and the truck just lost all power and was missing really bad. it barly made it back to the house. and i'm not sure were to start
when i first started it up this morning every thing seemed normal. untill it bacially fell flat on its face. The check engine light did come on and i'm having a friend come out at 5 to pull the codes. does any one have any idea what it is. or were i should start at. I have a bad feeling its going to be expensive. I got the truck with 145000 miles on it and havent had any problems at all. it has 165000 on it now. any help or ideas would greatly be appriciated. beacouse its our only truck and were going to need it soon for when we start taking soy beans off. Thanks |
Wait til you get codes, then worry. May be IDM, may be CPS, maybe all kinds of things, codes, then work it.
i just pulled it into our garage to get it out of the rain. and i had to put in 4L to make it in there. |
CKP = Crank Shaft Position Sensor
UVCH. is it like its running on 4 cyl and sounds like a big cam race car?
I just went out and started it up and let it run for a minute or so. and the paggenger side exhaust manifold was warm but the drivers side was cold. yea it sounds like it has a big cam
UVCH is that the under valve cover harness
yup. check the connection in the center of the valve cover on the valley side. if that is good, i would remove the valve cover and check that down there. mine poped off a couple weeks ago. there is a chance that it is fried as well.
ok i'll go and pull the valve cover and see what i find.
I got the valve cover off and every thing appeared to be ok I didn't see any broken wires and all the plugs seemed good
