Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
  #21 (permalink)
Old 10-05-2009, 07:53 PM
nccatfan nccatfan is offline
Send a message via AIM to nccatfan
I was given a $2000+ estimate when my UVC harness melted on the '94! Was told $600 for the engine harness and then some for gaskets and UVC's. I ended up buying the Motorcraft VC gaskets and UVC's (about $200 for all that) and found new connectors online for $20-30. Cut off the old ends and soldered the new connectors in... ran just fine after that.
  #22 (permalink)
Old 10-05-2009, 07:54 PM
2005F250 2005F250 is offline
There trying to rip you. Go in there and let them know that you know whats up and then see what they have to say.
  #23 (permalink)
Old 10-05-2009, 07:59 PM
ZombieWeinerDog ZombieWeinerDog is offline
That is a lot of money. To bad you dont have a 7.3 cause I have an ICP I would all but give ya!
i am in need of one, how much?
  #24 (permalink)
Old 10-07-2009, 12:34 PM
STANGMAN893 STANGMAN893 is offline
240.00 in parts and 4 hours in labor.It can be done in less time if you have small hands.
I work for a delaer and just asked a technician here.Located in the back of the high
pressure pump.
  #25 (permalink)
Old 10-09-2009, 10:06 PM
jfryjfry jfryjfry is offline
any update???
  #26 (permalink)
Old 10-30-2009, 09:58 PM
powerhoghp powerhoghp is offline
Question
Ummm, what about if they had to replace other parts of the harness, not just the sensor and pigtail(don't forget those are ford prices for parts too....)? And to clean up the oil on the firewall/block, change the oil/fill, and test it. Mine needs replaced and is slowly leaking, but when ford (parsons ford wv) replaced a leaky exhaust segment before the turbo, but in their lazyness they decided to rivet instead of bolt the heatshield back on the turbo..... So ill have to drop the front driveshaft and work from below( I am not going to pull the turbo, too much work and I'd have to get new gaskets for it).
Sorry about that mini-hijack. But 1000-1400 sounds fine depending on what they are doing and if they actually have a diesel tech working there..... Where in wv are/were you?
  #27 (permalink)
Old 10-30-2009, 10:11 PM
Code03 Code03 is offline
Yes, here's a like to another thread where things have been updated. Read it and if you have any info on this please let me know thanks...
6.0 Died at stop light
