HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-04-2009, 09:14 PM Thread Starter
4evaskrud's Avatar
HELP!!!
Im having a issue, The truck is loading up with fuel and not moving. Its just idiling and SMOKING. Maybe a egr issue? not sure then when i got home i got more good news, antifreeze in the wheel well. and all over the d/s running board.. BTW i have a 06 lariet F350 with an afe intake and a edge programmer.
4evaskrud is offline
post #2 of 4 Old 10-04-2009, 09:16 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Sounds like your blew the EGR cooler. White smoke out the exhaust?
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #3 of 4 Old 10-04-2009, 09:23 PM Thread Starter
4evaskrud's Avatar
couldnt tell what color the smoke was is was dark outside. but it took about 5 min to clear out and run again. u think head gaskets also?
post #4 of 4 Old 10-04-2009, 09:36 PM
scuffs *****
Tyler's Avatar
Is the truck stock? If it is, I wouldn't guess the head gaskgets going. But if they did blow, check your oil. See if there is water in it. If its still oil, then I'll bet its the EGR cooler.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
