Originally Posted by jared118
I have a superchip flashpaq programer, when I run a diagnostic scan it comes up with 9 codes
p0261
injector circ low- cylinder 1
it does this for the following 7 cylinders but with different codes
and on the 9th code
p0611
fuel injector ctrl mod perf
does anyone know what this meens or what I should do?
Replace the FICM. P0261-P0282 are Cylinder low codes. P0611 is a FIICM performance code. The only way you can get a P0611 is if the FICM doesn't see the desired 42-49v on the FICM MPWR led. It's complicated. Check your charging system as most FICM's fail due to low battery supply voltage that overheat their inverters. Also FICM's are expensive, around 600-800 bones and they come from Ford blank so they will need to be programmed by a dealer. They cannot bench program these modules.
