6.0 Blowing antifreeze
I have a 2006 F350. I've added a turbo back exhaust, cold air box and an Edge Evolution tuner. I tow a 11,000 lb 5th wheel in #2 Tow mode and I've had nothing but problems from my 6.0.
I've replaced the oil cooler, EGR cooler (new one from Neal Technologies),replaced the Bottle & Cap and have had the head gasket replaced and I am STILL blowing antifreeze when towing up a steep grade and now I have light puffs of smoke from the exhaust. What do I try next?
Have you tried a different edge tune? Like say, an economy tune? How are your EGT's when towing your trailer?
Blowin White Smoke
who replaced the gaskets? oem ford gaskets?
i take it the motor isnt studded. they could be blown again, warped heads. |
I had ARP head bolts installed when the head gasket was replaced. I was told that the heads did not need machined.
who did the work? they need to be machine when they are new from ford
All American Ford in Mocksville NC
head on back and tell them its puking again and you want the heads replaced or take it to a machine shop yourself and deck it
thats what i did with mine...unless they find another problem that is causing it to puke |
I would do the cooler delete kit and get rid of the edge tunes.
If I do a cooler delete kit I've read that the check engine light stays on. Is that true? |
