Bad PCM? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 09-27-2009, 12:52 PM Thread Starter
Bad PCM?
I really ned some help with this 95 7.3 powerstroke. No one knows this trucks here in Sweden. It just died and smelled burned cables. It was the contact to one of the valvcover harness, the pin to one GP was fried. Its changed now, but the truck wont start. No wait to start and the check engine light is on. I got power on the GPR, but it never turns off. When i crank it says vater in fuel-fuel filter-engine temp. Cant se any RPM either, it sems to move a little, thats all. The batterys, GPR and CPS are changed. All fuses are good. Can the PCM have been destroyed by the shortcut? And where is it located, cant find it.
scirocco is offline
post #2 of 18 Old 09-27-2009, 12:59 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
It sounds very much like the PCM is fried, however try unplugging the the lil sensor on the fuel bowl and see if that fixes it. It can short out and cause smiler symptoms. I cant remember if its the water in fuel sensor or the fuel bowl heater but its one or the other!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 18 Old 09-27-2009, 01:00 PM
Quoted: 6 Post(s)
Oh, and Welcome to the ORG!
post #4 of 18 Old 09-27-2009, 01:11 PM Thread Starter
Thanks, will try that. But where is the PCM? I have looked everywhere in the cab.
And this is the truckhttp://bilder.nightforce.se/visa.asp?ID=318
scirocco is offline
post #5 of 18 Old 09-27-2009, 01:17 PM
Quoted: 6 Post(s)
Nice looking truck.
The PCM on a 95 is located under the dash near the parking brake I believe it is removed by dropping the inner fender well on the drivers side to gain access and unbolting the wiring harness via the 10 mil bolt in the center of the plug!
That should be it. I am going off of what I can remember as I now have a superduty and it is slightly different.
post #6 of 18 Old 09-27-2009, 01:27 PM Thread Starter
Great, going to look again tomorrow. Another problem is finding parts here, its a pretty rare truck in Sweden. And thanks for your help.
scirocco is offline
post #7 of 18 Old 09-27-2009, 04:03 PM
Quoted: 6 Post(s)
Let us knnow what we can do to help ya out!
post #8 of 18 Old 09-28-2009, 04:53 AM Thread Starter
Still no luck. Searched everywhere for the PCM, found a lot of boxes, but none of them sems to be the PCM. How does it look like and where exactly is it? Someone got to now. Want to se it before ordering a new one
scirocco is offline
post #9 of 18 Old 09-28-2009, 06:34 AM Thread Starter
Yes, found the PCM .
They say the first thing going blind is the eyes.
So, now just have to find another one.
scirocco is offline
post #10 of 18 Old 09-28-2009, 06:47 AM
GoldieStroker944's Avatar
i was gonna say u can have them reflashed but it sweden i doubt it the other thing is make sure u unplug the sensor in the fuel bowl cause that can cause alot of problems down the road the other thing u can do (if u havent already) unplugg the batterys for 10 minutes and see if that does anything for ya
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
