replaced injector
i replaced an injector now is there a way to bleed the fuel or will ti do it on its own. it is running like crap like it has alot of air in it
What year truck do you have?
its a early 99
It will bleed itself. However, it's a good idea to pull the big plug on the back of the head before you remove the injector. If you don't, oil will run into the cylinders and could possibly hydro lock, causing some serious problems.
Just cycle the key several times to allow the pump to prime and bleed itself before trying to start the truck. |
