oil leak - Ford Powerstroke Diesel Forum
Old 09-18-2009, 03:23 PM
oil leak
my wife was driving my truck when it suddenly developed a major leak. everyone out here says its the rear main yet ive never seen one just pouring it out of the rear main seal. It is coming out of the drainholes in the bellhousing about 6 inches from where transmission bolts too the motor. it doesnt leak when just idling but after reving or driving it will pour out. please assist if you have been here
Old 09-18-2009, 03:44 PM
Send a message via MSN to dusted4eva
Check around your HPOP pump and follow the valleys with a flashlite. 99.9% it is coming somewhere from the top end and leaking down the tranny housing.
This may help you if you are running a 7.3 POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
Old 09-18-2009, 05:26 PM
Great site,Thanks
Old 09-22-2009, 08:51 AM
I'm betting it's your hpop as well.. check the lines coming out of it with a flashlight, you'll see the oil pouring out if that's what it is.
