Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 09-15-2009, 05:46 PM
No start after HPOP replacement
Hey everyone.
My brother in laws 02 7.3l had a stripped plug on the hpop so he changed the hpop out with a remanned one. He hasnt been able to get the truck restarted since changing the pump. Ive never replaced one before, but I assume theres probably some form of procedure like priming the oil in the injection system or something to that effect that he wasnt aware of. Could someone please enlighten me on what advice I can give him on what he needs to check and do? He did say that the hpop reservoir is full for what its worth. Also, I dont have hands on on the truck as Im stationed up here in Philly and they live back home in TX. Id really like to figure out what he needs to do as his truck is his, my sisters, and my nephews only means of transportation. Thanks in advance for any help.
Old 09-15-2009, 06:02 PM
Anyone have any ideas?
Old 09-15-2009, 10:34 PM
payne5757-First of nice Banshee and Fox. I got one of each myself. As for your brother in laws truck they are fairly strait forward. If the oil reservoir is full then check to make sure the Injection Pressure Regulator (IPR) connector is fully seated in the solenoid. Also check to ensure it is properly installed. The IPR screws into the pump on the drivers side and has a 2 wire plug that connects to the solenoid. The IPR comes in 4 pieces. First the body screw into the pump housing. Second the solenoid slides on. Third goes a spacer and last the lock nut that looks like a cheap stamped piece of sheet metal. If all those look okay then tell him to unplug his Injection Control Pressure sensor (ICP) located on the drivers side cylinder head. It's located about 4-5 inches from the front and has a wire connector plugged into the top of the sensor. With the ICP unplugged the PCM defaults setting the ICP to a standard 750psi and raises the IPR duty cycle. If it starts with the ICP unplugged it is a ICP sensor or connector issue. If it does not start it is most likely a IPR of high pressure oil pump issue. Also ensure the bolt at the front of the pump that holds the drive gear for the pump is tight.
Old 09-16-2009, 03:36 AM
Thx CaDieselGuy. Ill relay the info to him and hopefully it will help diagnose the problem. I
If anyone else has any other ideas, please let me know.
Old 09-16-2009, 05:17 PM
Anyone have any more ideas?
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
