2005 6.0 No Start this A.M. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-09-2009, 07:38 AM Thread Starter
AAA
Three weeks ago CEL code was low voltage to #7, cleared it, one week later CEL again code was low voltage to all 8 injectors. Truck never missed, smoked, spudered or lacked power. Last Thursday morning it cranked up but was loping and would not accelerate, let it warm up for 2 or 3 mins. then it ran like a camp. No CEL since the monday before. Started fine everyday since until today, no start. The only thing that was the same both mornings was the temperture. I live in Texas so summer is still here but this A.M. and the other day temps were mid 50 in the A.M.. Rmp gauge was working during cranking. Cranked at it 10-15 min on and off this A.M. battery were still hot.
Also have a 1999 7.3 (350,000k) which does the same thing, just thought it was old and tired, but it sounds like the same problem. Help me fix the 2005 6.0 and maybe I can dust off the 1999 7.3 and fix it also. thanks scott
AAA is offline
post #2 of 4 Old 09-10-2009, 09:18 AM Thread Starter
AAA
UPDATE
Replaced Fuel Injector Control Module that my wrecking yard buddy let me try AND Presto. Runs like the champ I remember.......
Hope this thread can help others with the 6.ooooohhhhhs
AAA is offline
post #3 of 4 Old 09-10-2009, 09:32 PM
Originally Posted by AAA View Post
UPDATE
AAA- I would recommend first check your charging system voltage. FICM's often fail due to low battery supply voltage. Cold temperatures make this concern more evident due to extended glow plug "on" times. With the engine at Idle you should have at least 13.6v at the alternator post. Low battery or charging voltage can adversely effect power to the FICM mpwr led. MPWR led should have 48v running. Also I would recommend taking the truck to your local Ford dealer and have them reprogram your pcm, ficm and tcm to the latest calibration because it has some helpful cold start and performance enhancements. Also by reprogramming those modules you ensure that all the calibrations between the modules work together. There are countless numbers of calibrations for a 6.0L depending on multiple factors.
CaDieselGuy is offline
post #4 of 4 Old 09-11-2009, 07:17 AM Thread Starter
AAA
Thanks CaDieselGuy I will take your advise.....
AAA is offline
