water in system
got a 2004 king ranch f 250 got bad fuel lots of water how do i get it out of the system whith out killing the batt to runn the pummp over and over agine draining the filters constanlty got like a gallion out that way but it is still reall white and no signs of clearing up is there a way to drain off the tank without hurting anything and buying the stupid fuel line tool
Drop the tank and turn it upside down.
FPPF, little white bottle of wonder worker magic. It removes/binds with it's own volume of water, it's the shizz. Buy 3-4 of them and dump them in. Won't hurt it.
Google FPPF. I use it regularly. The return line dumps warm/hot fuel into a cold tank and build moisture every minute the truck runs with less than a full tank...I imagine all trucks do this..Also, drain and pull the filter and fill the bowl to the top with Diesel 911 before you start it again. |
