start fuel wire problem - Ford Powerstroke Diesel Forum
Old 02-23-2007, 05:27 PM
k, heres one for you techs. which line is the fuel supposed to come into the filter element from top or bottom? the two solenoids on the pass side of the filter element the one closest to the cab the bolt closest to the pass side gets really hot and smokes. i know its hooked up right. what is that, and the truck doesn't start.
Old 02-24-2007, 05:49 AM
if the solenoid is hooked up right but you have the fuel lines hooked up backwards you may be overworking the electric fuel pump by trying to pump fuel through the return line. hmmmm.... that sounds reasonable, it makes it easier for me if its written down LOL
Old 02-24-2007, 05:55 AM
BIG TRUCK, SMALL DRIVER
Did you get it fixed?
Old 02-24-2007, 06:06 AM
Desert Shield/Storm Vet
Just a wild guess but probobly the bottom because that would be where the water would settle out. I would assume the feed line would come from the top but I don't know for sure.
Old 02-24-2007, 01:46 PM
yeah i got it figured out, after i read my reply i went out and tried it LOL and it worked.... the bottom line is the feed line and it is noticeably bigger than the return line. and now that the fuel can be pumped into the element the solenoid is not overheating anymore. everything was hooked up right, i just had the fuel lines hooked up backwards down there at the crossmember... thats where i unhooked them to change the engine..... but didn't remember what went where.lol
Old 02-25-2007, 12:14 PM
Draw a picture next time hahaha, glad you got it fixed up, something we should all keep in mind when we are gleefully ripping things apart.
Gord.
