Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 08-24-2009, 01:24 PM
95 PSD dead....HELP!!!
Replaced IDM, relay still clicking. Removed IDM fuse and glow plug relay clicks on and off. Now its flatlined....no power. Was cranking with no start and also had no glow plug signal.....any ideas?!
Old 08-24-2009, 01:42 PM
Lifetime member
Yea, check your MEGA fuses under the hood...the one for the fuel heater.....I would almost put money on it that its blown. Sorry I cant rember which one it is. If that is the problem, unhook the connector to the fuel heater at the fuel bowl. The heater inside has broken loose and is causing a dead short....popping the fuse. Either replace the heater or leave it unplugged. Not really needed...depending on your location.
After all that,,,glow plug signal.....refering to a no wait to start light?
Old 08-24-2009, 01:46 PM
Lifetime member
keep us updated
Old 08-24-2009, 02:00 PM
<<<<Dreams Come True!!!!
subscribed
Old 08-24-2009, 02:06 PM
Beer, Bait & Ammo....
Old 08-24-2009, 03:07 PM
Well, I checked the #22 fuse and swapped it with anothe just to make sure. It is not blown but the truck is still dead. The batteries are alittle under voltage, but not event the radio will come on. Sure seems like a short !! Could it still be the fuel heater ? I cant get up in the truck to pull the conector... I screwed up my knee
It is the new style (96) fuel bowl. How does the conector come off ?
Thanks
Old 08-24-2009, 03:10 PM
Thats correct - The light will not come on.
Old 08-24-2009, 04:28 PM
Lifetime member
mmmm.....if nothing comes on, check all your battery cables/connections. I had a bad connection at the starter, and the truck wouldnt crank intermitently.
If the fuse is not blown, then the heater is fine.
Old 08-24-2009, 04:36 PM
I can jump the remote solenoid and make the start turn over.
Old 08-24-2009, 04:38 PM
Lifetime member
heres a problem flow chart....
ALLDATAdiy.com - 1996 Ford Truck F 250 4WD Pickup V8-7.3L DSL Turbo VIN F - 1 - No Crank/Slow Crank
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
