Fuel leaking
99 powerstroke .....Changed fuel filter now fuel leaking from the drain tube that is attached to the drain valve ...Only when engine runs for about 5 minutes.. Valve is closed
if i'm not mistaken, thats a pretty common problem aint it?
Ok when i pulled the old filter out it did not have a o ring on the filter housing ..The only gasket was the one on the top of the housing where the top screws on..I replaced the new filter on with the o ring on the plastic housing....Will that make a difference??????????
Marc im talking about the fuel filter is there a large o ring that goes on the filter element towards the bottom of the outside of the element its about 3" ..The old filter did not have one .. the only gasket it had was the the bevel cut gasket on top where the lid screws down Jeff
Thanks Marc just wanted to make sure that the filter was installed right with the proper o ring ....First time working on a powerstroke ......live and learn ..Thanks for the help will take valve assembly apart and replace o rings thanks..Jeff
