Abs Light - Ford Powerstroke Diesel Forum
Old 02-11-2007, 09:47 AM
Send a message via Yahoo to superman04
Abs Light
how can i reset this annoying ABS light on a 2001 PSD f250? i dont have an abs scanner, but someone told me there was a series i could follow to shut off the trouble code without doing it with a computer scanner. thanks
Old 02-11-2007, 09:54 AM
you cant just "reset" the light. If the light is on...there is something not right with the abs system and the light will not go off till that problem is fixed. You need a scanner to figure out what is going on.
There are a few things you can check yourself though...if your cruise is inop...and or your speedo doesnt work...there is a good chance its your rear diff speed sensor. If those are not the case....then the most common other cause is one of the front speed sensors if you have four wheel ABS....inspect the wiring that runs to the speed sensors on the front tires close to see if there is any damage....without a scanner though...thats about all you can do....
Old 02-11-2007, 01:06 PM
is there a light on the dash that comes on when the cruise control is engaged? i cannot seem to get the cruise to work. i really need to find an owners manual for this truck.
Old 02-11-2007, 01:08 PM
Cool
oh yea and where would this "rear diff speed sensor" be located. thank you
Old 02-11-2007, 01:34 PM
top of the rear diff.....only electrical connector there...they are under 15 bucks at the dealer...
Old 02-11-2007, 02:13 PM
Welcome to the Forum Superman, It's a great place to get the info you need, and lots of helpful people here willing to give a hand when you need it. good luck with your problem
Gord.
Old 02-11-2007, 06:38 PM
Thank you for the welcome. I already feel right at home here. I just purchased this truck and I know I will need a lot of help and advice along the way.
Old 02-11-2007, 11:10 PM
That's what were all here for, everybody tries to help everybody else as best we can, and if we can't, we'll give you moral support hahaha.
Gord.
Old 02-12-2007, 06:54 AM
moral support may come in handy as well!
Old 02-12-2007, 09:36 AM
hahaha always does, at least for me anyways.
Gord.
