2005 6.0 with no boost and overboost/ with intake backfire - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-08-2009, 11:32 AM Thread Starter
Ok I am new here and have search the web and your site and cannot find a solution to my problem. I will try to explain the best I can.
A year ago my 2005 6.0 F250 turbo started to overboost ( to 40 on the gauge) and then back fire or gasp for air as I let off the pedal . Shortly after I had no bost at all flat. What suck is that I was in colorado and I couldn't gut up the hills. I stopped and let cool / removed the battery terminals. After doing this the turbo started to work again. So I took it to a dealer and they couldn't reproduce the problem but rebuilt the turbo under warranty. The day I pick it up and drove of the lot. IT DID THE SAME THING. I wonder if they did anything. so turned around and took it back. So they replaced the turbo and I went on my way. A week later IT DID IT AGAIN! So screw that dealer.
I call another and explaind the problem to them. They were able to reproduce the problem but didn't know what would cause it. So they decided to replace the turbo... Again. and it worked. Problem gone until summer came again.
So here I am with this 6.0 that wants to chew up and spit out turbos. I know how a turbo works but I really dont think the turbo is bad. I feel either I have a sensor issue, sucking air some where, intercooler might have oil in it , or my fuel pump is not applying the right pressure.
The truck it is stock. in 06 for reprogrammmed the PCM why I dont know. And I have a new turbo with 20,00 miles on it. The total miles on truck are 124,000. I have NO check engine lights. and I only get 15 MPG..
WHAT IS WRONG PLEEEEAAASSSEEE HELP!!!!!!!!!!!!!!!!!!!!!!!!!! any advise would be great. If I dont find a solution soon I might just ditch the heck out of her!
bluwolf57 is offline
post #2 of 7 Old 07-09-2009, 10:42 AM Thread Starter
Still looking for some advise.
post #3 of 7 Old 07-10-2009, 07:52 AM Thread Starter
Got an error code today. P2262 ---No Boost detected. Does any one have a clue what is going on?
post #4 of 7 Old 07-10-2009, 08:22 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
What are your MAP/BARO/EBP readings at key-on/engine-off? A P2262 by itself tells me either the MAP sensor hose has blown off the intake or you have a plugged converter. Does the engine free rev to 3800 RPM when you hold the accelerator to the floor?
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #5 of 7 Old 07-11-2009, 11:09 AM Thread Starter
AANot sure on the reading I used the local auto parts store reader. The map sensor is on and not blown off. the engine does free rev.
post #6 of 7 Old 07-11-2009, 11:20 AM
97 golden stroker's Avatar
you may have in problem with you wastgate i think that is what ford calls them. but anyways it is in the middle of the trubo and controles the boost. and if that is bad it may be you problem. dont quote me on this as i have not looked at the truck for myself but that is what i would look at.
97
afe intake
ats intercooler
3in. down pipe to 4in str8
fpr shim
terminator hpop
warm up valve delete
tw 6 position
southbend clutch
Stage ones from Rosewood diesel
SD IDM
d66
12000k hid dual element
thinking real hard about a nozzle upgrade
220k
97 golden stroker is offline
post #7 of 7 Old 07-13-2009, 06:22 PM
ajpu1983's Avatar
I ran into the same problem this week with a 6.0 It was popping and pushing air back through the intake. I took the turbo apart and the unison ring and vanes had seized up. Cleaned the vanes, ring, and housing and still had the same problem. Got to thinking what would be damaged from seized up vanes.... the VGT solenoid. The oil-actuated solenoid that moves the vanes. Replaced the solenoid and problem solved. Also the solenoid does not come with a new turbo. They probably only replaced the turbo and not the solenoid. A Ford tech can access the VGT PID and control the servo while watching the solenoid. The solenoid can be changed in 30 mins
ajpu1983 is offline
