Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 06-30-2009, 03:39 PM
fire370 fire370 is offline
No oil squirting from #3 injector
Right in the middle of harvest and need every single truck I got. Pulled the valve cover due to miss and I have no oil on #3.. New valve cover gaskets a couple of months ago. Playing with the connectors does absolutely nothing. Gotta get it back on the road like now.
94 crew cab psd 4x4 w/ 5 spd.
Thanks guys in advance.
Old 06-30-2009, 03:42 PM
wriott wriott is offline
BUILT & BROKE BY ME
either electrical or bad injector, can you swap harnesses from the other bank and see if it works then. if not then its the injector
