Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 06-28-2009, 10:22 PM
shortnotice shortnotice is offline
Violent Popping Sound and Air Exiting the Intake
My 1996 E-350 was running great all day yesterday. I started it up later in the evening and drove it about a block when it started making an extremely loud popping noise, in time with the engine. If I accelerate, the pop quickens. I shut the van down, removed the air filter, had my buddy start the motor, and with every pop came a burst of air out of the intake.
Is one of my intake valves failing to seal? Could that be a bent rod? Any other ideas, and what to do?
I have never worked on a 7.3 head before, but maybe now is the time to learn.
Most important, is it safe to drive it 2 miles back to my shop?
Old 06-28-2009, 11:12 PM
gmsmith36 gmsmith36 is offline
they have some push rod issues. could be a bent valve. poping through the intake you could have a broken exhaust push rod or a rocker arm failure.
Old 06-28-2009, 11:13 PM
i would drive it very slow if at all. 2 miles would be a easy tow rope job.
Old 07-09-2009, 11:25 AM
Here's my problem...
Do you think I should just put a new push rod on and try and get a few more miles out of it, or get deeper into it?
Old 07-09-2009, 11:37 AM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
ouch.... you could probably put it back together to see if it still makes any noise, does everything else look good??? if it were me i would dive a little deeper to check things out though. ne sense in making things worse..
