please help! - Ford Powerstroke Diesel Forum
Old 02-06-2007, 05:00 PM
please help!
ok ive got a problem with my truck 95 250. so this is what was happened
Old 02-06-2007, 05:05 PM
Jon
Guest
Posts: n/a
Looks like everything is ok
Old 02-06-2007, 05:07 PM
please help!
ok ive got a problem with my truck 95 250. so this is what was happened sunday morning i was leaving to go to church started my truck ran fine got out of my drive way went about 500 feet truck cut off like someone turned the key tryed to restart it would crank wouldnt start. tryed a new glow plug relay seeing how my wait to start light wasnt coming on iam gettin power to the hot side but with the key on nothing to the glow plug side. my over drive light is constantly on when tryin to crank the truck. non of my lights ie water in fuel enigne temp lights are not coming on when i turn the key to the on postion when i crank the motor they come on all but the wait to start light.i put a new pcm in mechanic told me that was what it was,it didn't do nethang still the same symptons! any help would be appreciated, iam basically stranded without my truck and tryin to get way to get to work with no luck.
Old 02-06-2007, 05:25 PM
is there any way to know if the pcm is workin correctly with out havin to take it to a dealership?
Old 02-06-2007, 05:28 PM
BIG TRUCK, SMALL DRIVER
Have you checked all of the fuses under the hood?
Old 02-06-2007, 05:29 PM
yea when it done this it blew the number 22 and 18 maxi fuses i replaced them and still nothing
Old 02-06-2007, 05:31 PM
did they blow again? You may have a shorted fuel heater.
Old 02-06-2007, 05:32 PM
no they havent blown since i replaced them. thats why iam at a lost with this thing something just aint adding up to me,i thought maybe yall could give me a idea of were to look to figure this one out
Old 02-06-2007, 05:36 PM
There are many others here smarter than me. They should be along soon.
Hope we get you goin!
Old 02-08-2007, 06:15 PM
I have the same symptoms... I have a 96 ps doing the same thing I have changed everything you have... Let me know how you made out.. I am stuck as well. Also I am getting no tach while cranging the engine and no wait to start light.
Thanks
