Edge Products
Edge Productsl |
edge cts attitude/juice issue
Hey guys, ive got a slight issue with my edge cts attitude/juice tuner
if i go anywhere near water it will just cut out if i go through a small water crossing any deeper then half up the wheels the truck will just cut out and will only crank, the connections have no water in them and all seals are still there, and when it stalls, i can unplug the crank sensor, icp sensor and the sensor under the turbo/intake manifold and replug the ford harness in (making the edge useless) and it will fire up and run fine even with water over the bonnet, no water or moisture gets on the module which is mounted up as high as possible on the firewall when it stops, after a few hours i can plug it in and all will be fine till next time, just wondering if you have heard of this issue before or if there any way of fixing it, have used electrical grease on all connectors but it still happens, also how safe is it to use the "extreme" setting, could you use it all the time or only every no and then thanks |
Hey Aussie! Glad to see someone using PSD's back home. My guess is that the Edge is picking up something the trucks computer is not. Maybe water in some lower connection that the edge might be more sensitive to. My cousins over there stopped using Fords because the water was shorting out the electrics on the 4x4. Just my thought, but I'm not too familiar with electrics and tuners yet. Good luck with it mate!
Nissan Patrol, nice! (of course pronounced Niss-san, not neesan like they say here....
) I would love to have a Toyota Hilux diesel over here! Hope you get it worked out!
