Boost Numbers on Early 99
Alright, I have a mostly stock Early 99 and I am just wondering what is typical boost numbers when pushing real hard while towing in an 80 HP tow tune (ie I am using DP tuner).
See sig for truck details, as I said its pretty much stock... NOTICE THE LACK OF ANY EXHAUST MODS... You will soon see thread asking about these... wondering though if I could be limiting my boost because of this... I normally see around 20 psi in any tune but my 120 race, which can give me 24. |
stock I saw 16-18 psi bone stock
with my tow files I see 24-26 with 4" exh and afe stage II on the extreme I can see 28-30 but its out of it map .. so it is a waste this is in my early 99 |
I can pull 25-27 psi no sweat in 80e. If I keep on it, I can hit 30. Stock turbo, stock sticks, wastegate tightened up all the way but red line still plugged in.
Interesting
superduty4x4, I am unfamiliar with what you said about wastegate being tightened up all the way... I have heard of unplugging the red line but just have no interest in overboosting... Can you elaborate on your wastegate?
Stock I saw about 15-16 PSI 80e I see around 20 maybe 21 tops 120 race, see 20 easy, usually works up to 22-24. My boost gauge is mechanical and plugged into the map line with the t fitting. |
I'm thinking of opening mine up a little bit now... can't afford a new turbo
Thanks
Thanks Superduty4x4
30 at wot stock except ts and clutch and intake
I have a little Striker 2 65hp module on mine and it will jump to 20 real quick and then I'll get an over boost CEL and it will defuel and slow me down. How do I fix that again???
boost fooler
