early to late turbo upgrade help - Ford Powerstroke Diesel Forum
Old 05-17-2009, 07:37 PM
Send a message via AIM to fordfan99350
i'm looking for a list of parts i need to change to do the upgrade. ford part numbers might be alot to ask but would help alot.
engine is out of the truck and i would love to get this done before it goes back in.
thanks, john
Old 05-18-2009, 05:59 AM
I don't have part numbers, but:
Turbo
Pedistal
Up-pipes w/collector (go with IH bellowed up-pipes if you can afford it)
Spyder pipe
Intake plenums
Spyder to plenum boots/clamps
Old 06-18-2009, 11:20 AM
Does the early 99 have the air heater in the spyder pipe?
Old 06-18-2009, 12:33 PM
no it does not
Old 06-18-2009, 12:36 PM
I am upgrading to a late 99-03 turbo setup, and I was wondering if there is a plug on the early 99 spyder pipe that will work to plug up the AIH on the late 99-03 spyder pipe.
Old 06-18-2009, 12:37 PM
Thats Mr. Oil Leak.....
I know there is a plug but I don't know a part number. They say you can use a dodge (cummins I assume) drain plug to plug the AIH.
Old 06-18-2009, 09:54 PM
that is correct MR. wyane lol
Old 06-19-2009, 07:19 AM
Feedback Score: 5 reviews
Why upgrade, no benefit if you need a better turbo get a D66 bolts right up.
Old 06-19-2009, 07:22 AM
It was a cheaper route for me to go. I got everything for around $500. Plus, it gives me the option for a bigger turbo down the road.
