2 ?'s pls - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-04-2009, 09:37 AM Thread Starter
countryraised's Avatar
Question 2 ?'s pls
My truck is an early '99 F350 4wd. Cold air intake and straight thru exhaust. I'm going to put in a Bully dog shift kit.
What is the better chipset to use Bully Dog 6 position. DP Tuner F5 or an SCT? I want to be able to switch on the go, no pulling out a laptop.
Also best way to level the truck, has a bit of a nose dive.
thanks
countryraised is offline
post #2 of 9 Old 04-04-2009, 09:56 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Of those choices go with DP tuner
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 9 Old 04-05-2009, 09:22 PM
John Wood Nut Swinger
strokin_early_99's Avatar
Forget the bully dog shift kit, the DP chip will do more than that bullyfrog shift kit ever dreamed of.
If you run any kind of tuning you need to have gauges.
On the spring issue, get a leveling kit.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #4 of 9 Old 04-05-2009, 09:25 PM
choupique108's Avatar
i wouldnt even think about using bullydog in my truck. Go with the DP chip and youll be amazed.. Gauges are a must though. get with raul, he is a vendor here, he can get you all you need
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #5 of 9 Old 04-06-2009, 01:46 PM Thread Starter
gauges are in the plans, sounds like DP tuner will go in, no tranny kit though? I'd rather put in a kit than loose the trans.
What do most leveling kits take to install?
post #6 of 9 Old 04-06-2009, 02:02 PM
szyd's Avatar
From what i have herd a shift kit or a valve body is the way to go. JW valve body or the trans go tugger kit. Make sure you tell you're tuner that you have either or. I would suggest doing the trans mods first so you do not have to have the chip re burnt.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
4" BDS lift. With Bilstein's
all brought together by TW
szyd is offline
post #7 of 9 Old 04-06-2009, 02:08 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Get the DP, the gauges and there are always used leveling kits on ebay and craigs list!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #8 of 9 Old 04-21-2009, 01:51 PM
89mustaine's Avatar
I really like my TW tunes also, you can get a package deal from Raul@stealth, Guages w/ pillar and the chip at a pretty smokin price.
Early 99 7.3L
Ultra lite EGT, boost, TT
AFE stage II
TW tunes
5" strait pipe, black
Rebuilt Trans w/ Banks TQ
Manual TC lock up mod
DIY EBPV mod
Zoodad mod
4.5" leveling w/ 35'' procomps
one piece headlights w/ warn spots
smoked taillights
2.5% window tint 30% in front
sony stereo +amp ADS 10" subs
on dash dvd.
89mustaine is offline
post #9 of 9 Old 04-21-2009, 02:02 PM
Raul@Stealth Automotive's Avatar
out of those choices the DP... but any custom tuned Chip will do the trick
-Raul
Raul@Stealth Automotive is offline
