transmission cooler - Ford Powerstroke Diesel Forum
post #1 of 29 Old 02-17-2009, 07:57 PM Thread Starter
transmission cooler
I understand the early 99s dont have a T-mission cooler in the radiator, I tow a 5th wheel and need to know a good aftermarket cooler that will work. Early 99, 4"flowmaster turbo back, DIY filter,guages and chip to come soon.
bigtrain is offline
post #2 of 29 Old 02-17-2009, 07:59 PM
Raul@Stealth Automotive's Avatar
i would do the 32k in here: Heavy Duty Oil Coolers
its a big sucker and will def help you cool down those temps
-Raul
Raul@Stealth Automotive is offline
post #3 of 29 Old 02-18-2009, 01:23 PM
cvdenson's Avatar
Mine has the tranny line's going into the radiator.
Chris
Early 99 F350 XLT 4x2 CC LB SRW 6sp
Terminator modded HPOP, CCV, 203 T, SS HPX, ITP OBA, Oilguard, Intank/Prepump mods, Ford AIS/zoodad, ITP regulated return, 08 Differential Cover, Autometer Pyro/Boost, 4" MKO straight-piped, Diesel Site A/C Bypass, DieselSite Coolant Filter Kit, DP F5 (stock, no start, high idle, 80e), gutted/plugged EBPV, TurboMaster WG, Aerotank 55 gal replacement tank, AutoEnginuity
cvdenson is offline
post #4 of 29 Old 02-18-2009, 02:44 PM
BRS
Correct, my early '99 auto did not either. I eventually replaced the radiator, a cooling line, and upgraded to a 6.0L cooler when I was redoing a lot of things on the truck.
Cdevenson - I'm amazed, maybe it's because you have a 6sp? But that seems backwards. Are you sure it's an early '99? Also, with an early '99, how are you going to upgrade to the gtp38r you have in your sig?
Ben
Early '99 7.3L F-350 SRW SC LB
DP Tuner (NS,Stock,HI 1200, DT,40T,80T,80E,120R,140A), Coolant Filter, External Trans Filter, 6.0L Cooler, JW Stage I Trans, Dipricol Optix Gauges, AFE Stage II, MBRP 4" Turbo Back, ProComp 4" Lift Front, Skyjacker 6" Rear Leafs w/ 1" Block, 16x8 MT Classic II's
BRS is offline
post #5 of 29 Old 02-18-2009, 02:54 PM
cvdenson's Avatar
Maybe 'cause it's a 6sp. My build date is 6/98 so that makes it E99. I'm going to swap out the uppies, flange, pedistal, y pipe, and intake runners to make the 38r work.
Chris
cvdenson is offline
post #6 of 29 Old 02-18-2009, 02:58 PM
BRS
Wow, yours is even older than mine. Gotta love Ford and their inconsistency!
Ben
BRS is offline
post #7 of 29 Old 02-19-2009, 06:30 AM
superduty4x4's Avatar
Why would the hand shaker even need a trans fluid cooler?
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #8 of 29 Old 02-19-2009, 12:47 PM
cvdenson's Avatar
They can get warm too.
Chris
cvdenson is offline
post #9 of 29 Old 02-19-2009, 03:15 PM
They shouldn't get that warm though, should they? I never paid attention enough to know the handshaker SD's had a trans oil cooler... learn something new every day!
post #10 of 29 Old 02-19-2009, 04:58 PM
cvdenson's Avatar
To tell you the truth, I don't know. I've been considering getting a tranny temp gauge to find out though. How efficient are the tranny coolers that go thru the radiators as opposed to the external coolers that are common?
Chris
cvdenson is offline
