Slow to build boost. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-21-2014, 01:34 PM Thread Starter
I just installed my gauges and I cannot build any boost until I reach 1700 rpms and under a load. At that point will build 5 to 6psi. this is on my Swamp tuner on stock. I have the Swamp 175/146 injectors. Set on highest it will build up to 26 psi at full load. EGT will get to 1400 pretty quick. I've never run gauges before and it just surprised me no boost untill 1700 rpms. Is this normal? I can foresee a issue as soon as I pull a heavy load with my EGT? Thanks
Early 99, 25Swamp 175/146 injectors, swamps 5,000 miles. tunes. 4" exhaust, Swamps air cleaner. Adreian HPOP[/COLOR], Boost & EGT Gauges. 5 Speed.___[/COLOR]
whatsup is offline
post #2 of 7 Old 08-21-2014, 04:56 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
sounds like you have some sort of boost leak?
check the up pipes and intercooler/manifold boots.
are you running the stock e99 turbo?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 7 Old 08-21-2014, 05:07 PM Thread Starter
Yes It's stock. Swamps told me that the WW2 would fit on the E99?? I am going to replace the tubo pedestal this weelend because of an oil leak, I will replace my up pipes then. With 25 lbs of boost I am surprised that the up pipes were leaking but cause its on the pressure side I can see that now.
whatsup is offline
post #4 of 7 Old 08-22-2014, 07:11 AM Thread Starter
My main question is does all of these tubo's not build any boost untill 1700 rpm then with a small load on it?
whatsup is offline
post #5 of 7 Old 08-22-2014, 04:12 PM
Quoted: 249 Post(s)
the ww2 will help with spool up, and yes it will work. plus more boost/power/lower egts. from what i remember the stock e99 turbos spooled really quick. that leads me to believe you have a leak somewhere.
when my up pipes were leaking i could get 25 but that was it. after i fixed them it was a huge difference.
The Following User Says Thank You to blue99stroker For This Useful Post:
Corey@CNCFAB (08-22-2014)
post #6 of 7 Old 08-22-2014, 06:18 PM Thread Starter
Thanks, I will know tomorrow,
whatsup is offline
post #7 of 7 Old 08-24-2014, 05:41 PM Thread Starter
I guess that 1700 rpms with a load is normal to start boost? I replaced my turbo pedestal yesterday along with new up pipes and a wicked wheel two and no leaks were found and my boost range has not changed, same as before. And the oil leak that I was trying to stop is still there. It appears that thge rear main is leaking.
whatsup is offline
