More boost? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-18-2014, 06:06 PM Thread Starter
More boost?
On my 99 it seems like 14ish psi is all the truck will make. On my cummins I put a boost elbow on it to get more out of it. I know I'm only pushing stock fuel but is there some simple and cheap way to adjust the wastegate. Like a elbow or turnbuckle the holset chargers use?
01 Ram 3500 24V, 2wd dually, nv5600, 4:10s, SB single, edge comp, blue chip cover, airdog 150, aem, mbrp, boost/pyro/fp, boost elbow, silencer ring delete, scangauge II, timbo apps.
Early 99 F450, zf 6 speed, 4:88s, boost/pyro, factory straight pipe
chumminz01 is offline
post #2 of 5 Old 07-18-2014, 06:14 PM
Quoted: 27 Post(s)
plugging the red line on a boot clamp will get more boost. but with only 14 psi of boost you have a boost leak. search here for boost leak detector to help find your leak.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
The Following User Says Thank You to strokin-7.3 For This Useful Post:
Corey@CNCFAB (08-02-2014)
post #3 of 5 Old 07-18-2014, 06:32 PM Thread Starter
I wasn't sure if these trucks were that big of slugs or not..14 is at 60 mph going through the gears if I can get 7-8 it's a stretch.
post #4 of 5 Old 07-18-2014, 09:15 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Everything he said plus look at your uppipes for leaks.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
The Following User Says Thank You to sbluke55 For This Useful Post:
post #5 of 5 Old 08-02-2014, 06:42 AM
My e99 was hitting mid to high 20s before the clutch started slipping.
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
The Following User Says Thank You to Tow51Stang For This Useful Post:
