E99 turbo hpop limits - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-19-2014, 04:10 PM Thread Starter
I have an e99 that gonna mod. Trying to decide if just gonna do 160 single **** injectors and tune. Or if should just put d66 turbo and 17 degree hpop oil pump with injectors. Looking to get around 400rwp. Was not sure of limits of the early turbo. Trans is built. Has intake and exhaust too. Any help appreciated. Also I know some won't tubbed the old PCM so might get the newer PCM too
echerbst is offline
post #2 of 4 Old 05-19-2014, 04:31 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Your gonna want to skip over the 17 deg hpop all together. The hotter tunes will really push the stock hpop to the max, setting the SES light. Go for one of the aftermarket Hpop's. You maybe able to just install a WW2 into your stock turbo and be fine, its cheaper too lol. I belive with 160's you maybe able to squeak by on a stock turbo without the upgraded ww2 but buying the d66 cant hurt either. Just make sure that you get the turbo, hpop, and injectors installed before buying a chip. Best of luck
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #3 of 4 Old 05-19-2014, 04:49 PM Thread Starter
Was gonna put a terminator or adrenaline hpop in. Not stocker whick one would u recommend.
echerbst is offline
The Following User Says Thank You to echerbst For This Useful Post:
Corey@CNCFAB (08-17-2014)
post #4 of 4 Old 01-24-2015, 01:30 PM
t500 is a good hpop, you can do 160/30s no problem with hpop upgrade and chip its not too much to ask from the stock turbo but you would benefit from the D66
I looked into my wallet and it was empty, I looked through all of my pockets and they were all empty, Then I looked in the garage and said to myself yeah it's all worth it
E99 F250 EC SB 4x4
AFE stage 2, 4" MBRP exhaust, DP tuner F6 8 tunes, ISSPRO pyro, trans, and boost guages, wastegate mod, CCV mod, Harpoon mod, Hutch mod, EBPV delete, Cooper AT 285/75/16, TracRac ladder racks, And in the future big oil, injectors, and D66 turbo
JFC73 is offline
