e99 oil leak - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-18-2014, 09:37 AM Thread Starter
e99 oil leak
Hi new to this forum, I own a early 99 f250. I have been taking down and fixing a couple oil leaks. The last one has me confused.
Oil is leaking down the back of the block and dripping down the inspection cover, about one drop per seven seconds while running. The back of the valley is dry. Any ideas? Thanks
petemoss 1987 is offline
post #2 of 5 Old 05-20-2014, 04:35 AM Thread Starter
I pulled the flywheel inspection cover and the oil is coming from the passenger side of the block but more towards the center. Could the lower pedestal o rings leak like this without getting a bunch of oil in the valley?
post #3 of 5 Old 05-20-2014, 04:56 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yup that or the EBPV could be leaking. The drain is in the back corner of the block.
Did you stick your hand or something all the way back an come up with no oil? Your hand should fit behind the turbo.
Oil rail plugs can also leak, as can the valve covers. Take the downpipe off and you'll get a real good view of both on the passenger side
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 5 Old 05-20-2014, 09:46 AM Thread Starter
Yeah I can see the drain in the valley. Ebpv is not leaking and back of head is dry. As much oil is leaking the valley would be very wet in back and its not. looks wet around starter also.
post #5 of 5 Old 05-20-2014, 09:54 AM Thread Starter
Good idea on pulling the downpipe, I'll do that
