Air filter - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 05-15-2014, 03:40 AM Thread Starter
Air filter
I have a early 99 f250 that the air box is cracked and needs to be replaced.
I've been reading and have found several to be the "best" so I'm looking for some opinions. What I have found is S&B, AIS, AFE, & Tymar all the be the "BEST there is".
Rate them for me.
thanks
bertieb is offline
post #2 of 14 Old 05-17-2014, 07:17 PM
To be honest, i removed mine complety. I did the crank case vent mod. and built my own intake out of PVC pipe. and just use a huge filter from advanced.
the truck seems to be running better because of all the air that it can get. But im going to follow this to see what other people say.
also if you have not done your crank case vent mod you really need to do it because your turbo right now is sucking oil from the crank case.
e99 7.3 Crew Cab 4x4
6.0 Trans Cooler
06 Mirrors (wired all but heat) 06 step bars
36" Tires/factory 06 18" rims
PHP Chip/Glow Shift Gauges
Crank Case Vent Mod
600k miles and still running strong.
AdamCap is offline
post #3 of 14 Old 05-17-2014, 07:27 PM
strokersixo's Avatar
Quoted: 32 Post(s)
Rate them for me.
thanks
Guys here would all agree that stock air filter is best unless you're heavily modding your rig. Was looking into the k&n till I read that stock is best. So still got stock.
Heavy_GD likes this.
--MAX--
strokersixo is offline
post #4 of 14 Old 05-18-2014, 12:33 AM
Rodslinger's B1TCH
look up "6637 intake" on here or google. you'll get a ton of info
steve604 is offline
post #5 of 14 Old 08-11-2014, 06:20 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
All 5 of the 7.3's I am responsible for maintaining have DIY intake/6637 filters. Cheap easy effective.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #6 of 14 Old 08-11-2014, 07:00 PM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
X3 on diy 6637 intake
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #7 of 14 Old 08-12-2014, 05:47 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
Riffraff Diesel 6637 Filter Kit - Riffraff Diesel Performance with the Early99 option...other wise the 6637 is a pain to find the correct 45 Deg tube
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is online now
post #8 of 14 Old 08-12-2014, 11:04 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
This being three months ago now, what is the end result?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is online now
post #9 of 14 Old 08-13-2014, 03:03 AM
hitmanheutel's Avatar
I bought the banks ram air intake setup. Not real sure if it made much of a difference over stock setup though. It is however a nice thick blowmolded housing that seems like it would be hard to destroy.
hitmanheutel is offline
post #10 of 14 Old 08-13-2014, 08:26 AM
Rodslinger's B1TCH
Ram air doesn't do much on a turbo engine
steve604 is offline
