ABS Light - Ford Powerstroke Diesel Forum
post #1 of 14 Old 05-11-2014, 03:56 PM Thread Starter
ABS Light
Hi,
I recently purchased a early very clean 1999 F250 crewcab/long bed with the 7.3l, 2wd, auto (127k) from the original owner. After owning it for about a week the ABS light started to come on randomly. Once it is on it will stay on until the truck is turned off, upon restart it is always gone. I have a scangauge II and have attempted to read the code when the ABS light is on and it states no code found. Brakes appear to be working just fine... Thoughts?
Thanks
walters665 is offline
post #2 of 14 Old 05-11-2014, 06:33 PM
aussie=effie
bob harris's Avatar
ABS LIGHT
ME TOO, VERY STRANGE BUT ALL WORKS FINE ??
bob harris is offline
post #3 of 14 Old 05-11-2014, 06:43 PM
heykw's Avatar
How are the front hubs?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #4 of 14 Old 05-16-2014, 01:08 PM Thread Starter
So today I was backing out of my driveway. While in reverse going down the drive I hit the brakes as I was attempting to switch to drive and the brakes began pulsing like ABS and took a long time to stop. Then they worked fine again. Funny thing, light didn't come on at all for this.
Brake fluid levels are good, attempted to burp the power steering pump the other day to make sure there was no air in it. Power steering pump going bad??? 127k on the original one.
post #5 of 14 Old 05-16-2014, 02:37 PM
heykw's Avatar
heykw is offline
post #6 of 14 Old 05-16-2014, 02:58 PM Thread Starter
Sorry but how do I check the hubs.
post #7 of 14 Old 05-16-2014, 03:24 PM
Quoted: 28 Post(s)
lift front tire off ground and spin it. if you hear scratching or growling replace hub. also grab tire at 3 and 9 position than push and pull. any excessive movement I'd replace as well. go ahead and remove abs sensor on top of rear diff and clean it off just because. (more than likely a front hub is the issue but why not clean rear sensor when it's free to do it). I had abs light come on a while back and I had to replace a hub and it went off shortly after.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #8 of 14 Old 05-16-2014, 03:26 PM Thread Starter
thank you, i appreciate it
post #9 of 14 Old 05-17-2014, 04:13 PM
heykw's Avatar
Barely lift the truck up off the ground and use some kind of a crowbar to pry on the tire from the bottom.
heykw is offline
post #10 of 14 Old 05-18-2014, 08:02 AM Thread Starter
Spinning I have some noise, flexing the tire at 3/9 and 12/6 it has a least a 1/4 inch of play on both front wheels. Sounds like the hubs are shot.
