should i buy this powerstroke? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-08-2014, 03:52 PM Thread Starter
hi im new to this. i am looking at buying a 2000 f350 7.3 powerstroke with 170000 miles. it has a 4" lift and he is running 37" tires. it has 3.73 gears. it rides really hard i read that the ride can be softened by spraying a lubricant in the leaf spring shackles and replace the shocks with the blisten shocks.it has 20" rims i'm wondering if i bought it and put 35" tires and replace the shocks and lubricated the springs would that make a difference in the ride. it also has a chip and a aftermarket air intake. if i replace them with 35's and drive eayt what kind of mpg is realistic. thanks
Bucky60 is offline
post #2 of 3 Old 05-08-2014, 03:57 PM Thread Starter
if i was to buy it i would put running boards/nerfs on it where is the best place to get wheel to wheel running boards at for the best price? thanks
Bucky60 is offline
post #3 of 3 Old 05-08-2014, 04:19 PM
sbluke55's Avatar
Quoted: 575 Post(s)
Garage
I would guess 16 mpg average between highway and city. If you want a better ride I would go with a tire and wheel combo that has more sidewall. I would recommend a 18" rim plus the tires are cheaper.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
