Steering gear box blown? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-02-2014, 09:48 AM Thread Starter
I was leaving work last night and in an instant I couldn't stop and had no power steering. These trucks are a ***** to drive when both of those go out at once. I thought it might be a high pressure line that blew but didn't see any leaks. Could it be a blown seal on the steering gear box? Can I get a seal kit and rebuild it myself? My trucks manufacture date is 9/98 so I'm guessing it's a 32 spline.
Dwight
99 F250 CCLB Pretty much a stocker
87' BMW DINAN M6 Too many mods to list
StoneGuy is offline
post #2 of 10 Old 05-02-2014, 10:02 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Usually when you lose brakes and steering it means power steering pump.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 10 Old 05-02-2014, 10:08 AM
ZMANN's Avatar
Quoted: 1350 Post(s)
sounds like a pump or hydraulic psi issue to me also
that little cylinder on the side of the hydro boost is supposed to store enogh pressure for an emergency stop if the hydro system fails but I have yet to see anyone not waste the stored energy on a few brake taps first LOL
We Miss you Ronnie
ZMANN is online now
post #4 of 10 Old 05-02-2014, 11:10 AM Thread Starter
Toss this around, if the gear box blows a seal and dumps the fluid you will have the same symptoms. My PS pump exhibited no issues prior to this happening. There is a nice puddle of what appears to be ATF underneath my truck. My friends has had this happen twice on his truck and had to replace the steering gear box both times. His pump is still good and serviceable. This is why I'm thinking it's the gear box and not the pump. I guess I can get some fluid and see where it's leaking but the hoses look sound.
Dwight
StoneGuy is offline
post #5 of 10 Old 05-02-2014, 11:32 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
The puddle of ATF makes a huge difference on the diagnosis. I would refill and watch where the leak is. Could be a hose, steering box, brake booster or the pump. If it is the steering box I recommend a red head steering box, they are a little spendy but worth it. How far did you drive when it was out of fluid? When you run the pump empty you have a really good chance of destroying the pump
01 f-250, Standard
sbluke55 is offline
post #6 of 10 Old 05-02-2014, 11:38 AM Thread Starter
I will report back my findings. Going to get some fluid and see what happens.
StoneGuy is offline
post #7 of 10 Old 05-02-2014, 11:39 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
How far did you drive with no fluid? If it was a while you have a good chance that you destroyed the pump.
01 f-250, Standard
sbluke55 is offline
post #8 of 10 Old 05-02-2014, 03:50 PM Thread Starter
Topped off the PS pump, started the truck and I don't see any leaks in the hoses but it's leaking out of the gear box. I have one on order and replacing hoses at the same time. I'm getting a reman. gear box, this one lasted 280,000 miles, new one has lifetime warranty.
I only drove across the street so I think the pump is fine, we'll see I guess. I have to go home tonight, grab tools and a change of clothes and work on it tomorrow. Luckily I have the company truck to run around in for the time being.
Dwight
Dwight
StoneGuy is offline
post #9 of 10 Old 05-02-2014, 04:33 PM
ZMANN's Avatar
LOL agreed
that lifetime warranty won't impress you if you have to change it more than once
hopefully it's a good brand and the sector lash is set properly
We Miss you Ronnie
ZMANN is online now
post #10 of 10 Old 05-03-2014, 12:12 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Dwight
Dwight
Leaking out of the gearbox is often the lower seal on the pitman arm. Costs about 10$ and pretty quick to change. I just did mine. Its a lot better than a whole new box
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
