Mismatched injectors.... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-27-2014, 09:16 PM Thread Starter
OK so I recently did injector o-rings to find that I have mismatched injectors.
I have recepts form PO and it says 4 injectors were replaced back in 2012 from a local shop.
PROBLEM is I have early99. I have 4 AB injectors on drivers side (stock I assume) and 4 AD injectors on passenger side (3 stock looking ones and 1 yellow top Alliant power rebult?).
Is this bad? I was thinking of telling the shop that did it but I might be 2 years to late. The truck is not the easiest to start, runs alright (only one I have ever had so nothing to compare to)
All I know or have been able to find online is that they flow different amounts of fuel. Cant be good right??
Early 99 7.3
MikeyKC is offline
post #2 of 5 Old 03-30-2014, 06:11 AM
The solenoids are interchangeable throughout the differing injector codes. There is really no way to know what the internals are short of taking them apart.
Sorry I couldn't be of more help.
Dan V is offline
post #3 of 5 Old 03-30-2014, 06:32 AM Thread Starter
Ok that makes sense but if i baught rebuilt ab injectors that came with ad tops I'd think something's wrong with that. So the only way to tell for sure is measure the flow?
Early 99 7.3
MikeyKC is offline
post #4 of 5 Old 03-30-2014, 06:44 AM
As far as I know.
Dan V is offline
post #5 of 5 Old 03-30-2014, 06:04 PM
timmyboy76's Avatar
there both a split shot injector, just the ad flow'n more...stillthink its not good to have mixmatched though.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
