Intake heater relay - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-21-2014, 06:26 PM Thread Starter
Intake heater relay
I have an e99 (5/98) and seem to have an intake heater relay next to GP relay. My truck came with a "cold weather" package. Anyone else have this set up? The relays look identical and I was also wondering what exactly the heater is? Is it more glow plugs or an actual heater of some kind? Thanks in advance.
Dorsal is offline
post #2 of 9 Old 03-22-2014, 07:53 AM
blue99stroker's Avatar
Quoted: 272 Post(s)
it for preventing white smoke at idle when its cold.
its pretty useless there is a ton of parameters that have to be present for it to kick on.
most of us get a AIH delete plug and get rid of it, its just a restriction.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 9 Old 03-22-2014, 04:14 PM Thread Starter
Thanks I was wondering about that. It does git a bit nippley here in the winters -10-15 on a regular basis. Would deleting actually HARM anything?? Thanks again for the reply
Dorsal is offline
post #4 of 9 Old 02-21-2015, 06:16 PM
dieselcrawler's Avatar
Quoted: 23 Post(s)
My baby girl is asleep on my lap and I'm waiting on her momma to get home from work... nothing better to do than dig up old threads!
Here's a pic of an AIH...
I would delete it and make sure you have a hi-idle tune... I use my 1200 rpm hi-idle a lot in the winter, but I never see -15.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #5 of 9 Old 02-27-2015, 08:03 AM
Question AIH delete
I was just reading thru the threads and saw that the E99 didn't come With an AIH. Now this link says they do. Am I missing something here, or do some of the E99 come with them. My truck was built in August I believe.
COP-OUT is offline
post #6 of 9 Old 02-27-2015, 09:35 AM
Quoted: 23 Post(s)
The OP's account of an early '99 with possible AIH is the first I've heard of... would be nice if they could post some pictures of what they have.
Greg
Semper Paratus
post #7 of 9 Old 02-28-2015, 01:56 AM
Quoted: 7 Post(s)
The early 99s did not have an AIH. If the OP's truck has one, it's been added by swapping parts, or an engine transplant. If that's the case, it probably doesn't do anything since there was no provision for the PCM to activate it, nor will the wires be in the main harness. Even if the PCM was swapped and the appropriate wires added, it's probably never even turned on due to the parameters for its activation being so narrow.
Pikachu is offline
post #8 of 9 Old 03-06-2015, 10:54 AM
Question on the intake of the E99. There is some type of sending unit in the middle of the Y between the cold air and hot air tubes. It has an couple of wires coming from it. So I am guessing that it is some type of sending unit. At first I thought it was an intake heater. Any one know what it is. Thanks. Ron
COP-OUT is offline
post #9 of 9 Old 03-07-2015, 02:49 AM
Quoted: 7 Post(s)
That is the MAT, manifold air temperature sensor.
Pikachu is offline
The Following User Says Thank You to Pikachu For This Useful Post:
COP-OUT (03-27-2015)
