Putting an OBS Motor In An E99 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-10-2014, 07:55 AM Thread Starter
To Many Projects
Twinjracing's Avatar
Quoted: 14 Post(s)
As some of you know a good friend had a E99 with a bad motor. He brought my 95 OBS motor out of the parts truck. I know we have to switch injectors, valve cover gaskets and harnesses over. Also change fuel bowl over and plug the return lines on the heads right. So my big question is the turbo are the OBS and E99 the same or not? Are the pedestals and up pipes the same? Is there anything else I need to know or change.
Thanks JJ
sent from my shoe phone.
17 F250 XLT CC LB SRW 4X4, Truxedo Lo Pro Cover, Spray In Bedliner, Airlift Bags, And Cobra 29LX
E99 F250 Ext LB 4X4 Terminator HPOP, Rosewood Stage 160/80, T4 Billet S366 66/74/1.10, NLTD Tunes, Custom Traction Bars, Custom Winch Bumper
71 Cutlass Supreme Dragcar, 66 GTO, And 72 Vista Cruiser
JJ
Twinjracing is offline
post #2 of 5 Old 03-10-2014, 11:20 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Alternator and A/c are on opposite sides. I think you need to swap the whole front cover, no big deal with the motors out and beside each other.
e99 turbo is different than OBS, I think the Up pips are the same though
CSIPSD could answer you better, IIRC he has/had an OBS motor in his SD
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 5 Old 03-10-2014, 11:22 AM Thread Starter
To Many Projects
Quoted: 14 Post(s)
Thanks
JJ
post #4 of 5 Old 03-10-2014, 11:25 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Pretty sure I'm wrong about the front cover, I found the thread where CSI posted about OBS motors in his SD ( hes done two) and no mention of that.
post #5 of 5 Old 03-10-2014, 11:42 AM Thread Starter
To Many Projects
Quoted: 14 Post(s)
OK thank you
JJ
