Leveling Kits - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-09-2014, 08:02 PM Thread Starter
Leveling Kits
I am looking for a leveling kit for my truck but since mine was built in 08/98 All the ones I find say that they wont fit. Any suggestions?
austinthompson11b is offline
post #2 of 5 Old 03-10-2014, 07:16 AM
Found my kit on ebay, just make sure the u bolts are square and not rounded off, only difference in the kits
E99 F250 XLT SuperCab 4x4 3.73 gears, 213k and climbing, ZF6 trans w/ 1944-60K SB Clutch/Flywheel, 6637 filter, muffler/cat delete w/ 5 inch tip, PHP Hydra, 4 gauge pod(EGT, EOT, FUEL PSI, BOOST), 12000 lb Warn Winch, 07 headlights/grill, 6k HID kit, Bushwhacker pocket style fender flares, Pioneer 7" touchscreen, 2.5 inch leveling kit with 315/75/16 General AT2s on stock 16 bullets, HPX
Next up: Rebuild Kit and Billet Wheel, Fixing E-brake so I can park on hills!
Tow51Stang is offline
The Following User Says Thank You to Tow51Stang For This Useful Post:
JHALL (03-24-2014)
post #3 of 5 Old 03-10-2014, 07:17 AM
Early 1999 Ford F250 2 8" Front Leveling Lift Kit | eBay
post #4 of 5 Old 06-02-2014, 05:13 PM
usramc's Avatar
Quoted: 2 Post(s)
Anybody use the shackles?
Early 99, 6 speed, ccsb, leveling kit on 35's, 6634, straight pipe, diablo chip.
usramc is offline
post #5 of 5 Old 06-02-2014, 07:01 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Buy the one from custom diesel out of Tennessee. I bought one and I love it. Also, you can build a rear shackle leveling kit out of 1\4 inch by 2 inch bar stock and make your own if you can weld. Just make them 3 inches longer than your stock shackles are hole to hole
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
